It works...But
keith
06-04-2003 17:46:00
Well I finally got my 8n running after putting new points and spark plugs. But I had to put a new coil on. Personally I didn't know which one to buy. I know that it was converted to a 12volt system. The coil I had bought didn't require a resister. My quistion is, does it really matter. If so what should i do? Thanks a lot. Keith
Dell (WA)
06-04-2003 17:56:51
 Re: It works...But in reply to keith, 06-04-2003 17:46:00
Keith..... ....I'm sure what you wrote makes sense to you, unfortunately, I flunked mind reading.
There are 2 types of 8N tractors, frontmounts with square ignition coils, and sidemounts with roundcan ignition coils. And there are 6 volt and 12 volt coils for each type. Square frontmount coils, wheather 6 or 12 volts require some sort of resistor.
Real 12 volt roundcan coils don't require any resistors BUT there are some roundcan ignition coils being sold as 12 volt coils with a little tag that sez: requires resistor, but who reads the tag, eh?
If you really want an answer, you'll need to clarify your 8N tractor ignition system..... ....Dell, a 12 volt advocate for the right reasons
tjw
06-05-2003 06:10:21
 Re: Re: It works...But in reply to Dell (WA), 06-04-2003 17:56:51
Dell,
I'm wondering where you took this mindreading course....none of the colleges around here offer it.....
Grin....
souNdguy
06-05-2003 06:38:07
 Re: Re: Re: It works...But in reply to tjw, 06-05-2003 06:10:21
Obviously 'mens' school... and -most- of us flunked it... Just ask any woman..
Soundguy
