8 Volt Battery
Earl Wade
06-01-2003 08:09:55
I have a Jubilee, still 6 volt system. Friend told me to get a 8 volt battery for better cranking amps. I did and it does seem to crank just a bit better, starts fast.
Is my 8 volt battery ok for this and will it cause any damage.
What is the advantage of the 12 volt conversion kit? Or why do most people make this change?
Thanks, Earl
Mountainman
06-02-2003 18:41:34
 Re: 8 Volt Battery in reply to Earl Wade, 06-01-2003 08:09:55
My 8N had an 8 volt battery on it when I got it. You ask what damage it can cause?
Well, like the others said it won't charge with out 'adjusting' the non adjustable regulator. And it provides more current than the coil can handle so it will repeatedly burn the coil out also.
In my case the generator went out and needed much more than brushes and with the regulator mucked up for 8 volts and the battery now failing I decided to go to 12 volts.
With 12 volts you can use a proper resistor for the coil voltage to eliminate that issue.
There are several reasons for the switch including ignorance. It will spin a low compression (worn) engine faster and that is the most common reason. Next is the cost factor - sometimes the six volt generator is expensive to repair and when faced with this cost as well as the battery replacement, folks get the much cheaper alternator.
I also understand 12 volts better than 6 and that was an added factor in my decision. If the generator had not needed extensive repairs I probably would have kept it 6 volts.
Or switch it back to 6 volts - you will probably need a regulator and coil as well as the battery itself of course.
hth
N - joy
Mountainman...CA
Pete
06-01-2003 11:48:01
Earl --
8v batteries are an odd item all to themselves. To my knowledge, nothing save locomotives ever specified them as original equipment -- certainly not the Ns.
What an 8v battery will do for you is: 1. Over-power your starter which will result in faster RPM at cranking, 2. Present problems for your charging system, since the generator only puts out 7-8 v and therefore cannot properly charge the battery, 3. Present problems for ancillary electrical appliances (eg. headlights) since they're only designed for 6v.
What an 8v battery won't do for you is provide better performance in the long run. It may mask an underlying problem, as Claus pointed out, but the problem is still there, and will worsen.
12v conversions will 'modernize' your N, but like the 8v thing, you really won't get any better performance out of it IF it is properly maintained in the first place.
It's ultimately your decision -- nothing really wrong with going 12v if that's what you want to do. As for all those that say that there's something wrong with the 6v system, I say that chances are the electrical system is fine and the fault is elesewhere. More than once our '40 9N has been started via hand crank in 20 degrees or colder just to prove it can be done.
Best wishes,
Pete
Claus
06-01-2003 10:32:43
This comes up once a month. Whenever someone buys a 8N, 100 well meaning friends come out of the woodwork, to give advice to change to 12 volts 8 volts, etc...They never tell you how to set the voltage regulator that cuts off at 7.5 volts and cannot charge the battery. The voltage regulators are not adjustable, but a knowlegeable person could perhaps adjust it but then they would not ask the question in the first place. The tractor worked for 50 years wuth 6 volta.. There is no extra money in cranking an engine faster unless it has little or no compression. Listen to your friends about ingrown toenails, but not tractors.
Run your tractor for a while before you go tearing into it. Then make a list....and prioritize it of things you want to fix/do. Putting an 8 volt battery in the tractor shouold not be one of those things.
Happy Motoring
Claus
