Order Ford 8N Parts Online
12v battery used on 6v 8N
Bob
06-01-2003 06:11:07
I have a friend down the highway who bought a well used early model 8N recently, and is running it on a 12v battery. It has not been converted. I have told him he is asking for trouble,burned out coil,and maybe the starter. What else is likely to happen to it?
Richard Fazio
06-01-2003 10:33:06
 Re: 12v battery used on 6v 8N in reply to Bob, 06-01-2003 06:11:07
I had the same thing. I bought an 8N with a 12 volt battery. The guy that owned it knew nothing about tractors. When the battery was dead he just went out and bought a new one. He hooked it up with a negative ground. I didn't know what I had. I ended up putting in a 6 volt battery and having to change the voltage regulator which was fried. It hadn't run long enough to fry the coil.
MikeC
06-01-2003 07:00:11
There should be no damage to the starter, however the coil and distributor internals are not gonna be happy. Besides, his 6V generator won't keep that 12V battery charged.
Are you sure that it has not been converted with a generator? There are some conversions that use a 12 volt generator that looks just like a 6 volt.
Bob
06-01-2003 07:12:30
 Re: Re: 12v battery used on 6v 8N in reply to MikeC, 06-01-2003 07:00:11
He said he doesn't think it has been converted
john
06-01-2003 07:18:26
 Re: Re: Re: 12v battery used on 6v 8N in reply to Bob, 06-01-2003 07:12:30
to find out if it has been converted start the engine and see the out put of the generator is 6 or 12 volts.
