Left spindle key and bushings
DJ
05-31-2003 13:37:34
I'm startng to take this apart to install new bushings. How do you get the key out???
The manual says "remove the key." Wonderful. That's like saying: "Disassemble, then re-assmble." Not much help. I didn't want to wreck it tryng to dig it out until I know. There must be some simple thing and I just don't see it. It's wedged in very tight, probably as it should be.
Willy-N
05-31-2003 13:50:45
 Re: Left spindle key and bushings in reply to DJ, 05-31-2003 13:37:34
I hope you have the arm off first before tring to remove it. To remove the arm take the bolt out amd spread the gap a little with a screw driver by tapping it into it. Then tap the arm up and off. Now you can see the key better. You can use a small punch to drive it in a arc to remove it or grab it with Vice Grips real tight and tap them with a hammer and pull it out. Sometimes they are tight. Mark H.
