Order Ford 8N Parts Online
8n stopped running
keith
05-30-2003 20:34:59
My 8n was running while I was takining off my box blade and all of a sudden stoped running. I have put new spark pluges in and new points and condenser. I am not a mechanic, but I am at my wits end. Plese help any one.
Claus
05-31-2003 18:17:41
 Re: 8n stopped running in reply to keith, 05-30-2003 20:34:59
Do you always leave your tractor runnning when hooking and unhooking implements? This is a good way to meet your maker....Don't let Dell hear this.
Happy Motoring
Claus
Pitch
05-31-2003 07:36:27
You have to go at it systematically. An engine needs three things to run compression,spark,fuel
#1 Do you have fuel? Is it getting to the carb? pull the drain plug from the bottom of the carb and see what runs out. Pull a plug and see if it smells of gas. Don't forget air is the major component of the fuel mix make sure your air cleaner is clean
#2 Check for spark at the coil and then at the plugs if no spark at the plugs check the distributer. Check these things then get back.
keith
05-31-2003 17:55:17
 Re: Re: 8n stopped running in reply to Pitch, 05-31-2003 07:36:27
Pitch, I took the drain plug off the carb. just a little bit of gas came out. I also turned the gas on to see if any would come out of the drain plug. nothing. What do i do next. Thanks
Pitch
05-31-2003 18:13:22
 Re: Re: Re: 8n stopped running in reply to keith, 05-31-2003 17:55:17
check your filters on an origanal tractor there will be three. One in the carb itself where the supply line enters,one is the sediment bowl remove and clean and there is one in the fitting that the sediment bowl mounts ont the bottom of your tank with. Mine sediment bowl assy had been removed long before I got my tractor so I have no knowledge of how that filter is in there.
Rob
05-31-2003 02:48:40
Well be sure to open up the fuel valve two turns.
Tommy (TX)
05-30-2003 21:02:54
Keith...does it have fuel?? Ya need a good steady stream..(not a little wimpy one)...Now if it was runnin' around 45 min..& then konked out..it could mean a bad coil...'bout 10-15 min...might mean a bad ignition switch...20 sec's....a bad condensor...I'd check your fuel flow first though.....
HTH
Tommy
