Killing mesquite trees
how much detergent
Terry Alexander
05-28-2003 10:49:43
I am going to kill some mesquite trees. Per the instructions of the service, I am mixing 6.4 oz of Remedy to 2 1/2 gal of water. He also said to use regular dishwashing soap as a surfactant. What I failed to ask was how much detergent would you use in 2 1/2 gal?
As usual....TIA
Terry Alexander - 1950 8N
Rob
05-29-2003 02:54:28
 Re: Killing mesquite trees - how much detergent in reply to Terry Alexander, 05-28-2003 10:49:43
It doesn't take much. A big squirt is closer then 1/2 cup. As long as it spreads out and hangs on. You can always add more.
Bill
05-28-2003 13:37:36
I used to agonize over the same question. A friend told me that growing up on a farm in Missouri that they used something like a cup in 300 gallons of mix. Now I put a small squirt in a couple of gallons.
KWP
05-28-2003 11:06:09
1/3 TO 1/2 CUP IS PLENTY, ADD IT AFTER YOU FILL YOUR SPRAYER(OR IT WILL FOAM OVER)THEN SHAKE AND SPRAY.
