2N Dies
Dave Stevens
01-06-2001 15:09:00
After half hour or so my 2N just dies and will not start unless I let it sit for an hour or so. I installed a new carb and that did not help. I checked for spark after it dies and that is OK. I put in fuel additive just in case I had some water and that didn't help. I am about ready to plant flowers around it as a yard ornament. Any ideas will be greatly appreciated.
Dave
gillman
01-07-2001 17:55:14
 Re: 2N Dies in reply to Dave Stevens, 01-06-2001 15:09:00
mine had clogged fuel line from tank down to carb. changed sediment bowl and blew out lines.runs fine now. i plan on cleaning inside of tank in spring.
Danny in CO
01-06-2001 21:17:47
Dave,
Turn of the gas. Disconnect the fuel line at the elbow going into the carb. Now turn the fuel on again. You should have a steady stream of gas out of the line. If there is minimal flow, check the 2 filters in the shutoff valve. One just above the sediment bowl and one on top of the shutoff valve in the tank. The last one requires you drain the tank first and then take the shutoff valve off the tank. Also, take the elbow of the carb. There should be a filter there.
This was my problem, but it surfaced after about 5-10 minutes running.
HTH!
Danny
Bri9n
01-06-2001 15:19:14
When my 9n had similar symptoms it turned out to be the coil...
Timk
01-06-2001 22:01:54
 Re: Re: 2N Dies in reply to Bri9n, 01-06-2001 15:19:14
No. It can't be electrical here since he says he has a spark after it won't start. Unless the spark is weak that is. If it's a hot, blue spark, I would assume the plugs are also working ok since the tractor does run for awhile, hence, must be a fuel problem. I would also not discount the possibility of water in the gas tank. My $ .02
