Knockin
Justin
05-27-2003 17:50:41
I've just fixed an oil leak on my 8N (49'). Now I've got a potentially bigger problem. There is a loud knockin between her spark plugs and oil pan. It seems to increase in sound when shes in gear. When I put the clutch down it lessens and even stops at times. Very few times! Need comments/answers if possible. Thanks in advance, Justin.
Evil Steve
05-28-2003 07:51:56
 Re: Knockin in reply to Justin, 05-27-2003 17:50:41
Classic symptoms of a bad rod bearing. As BOB suggests, your oil leak may have been a cause. Until your KNOW the answer, I advise you to not run that engine.
BOB
05-27-2003 19:35:58
Justin, where was this oil leak?
how far did you rip into this?
trying to help BUT need more info to help you out?
was tractor split?
BOB
Justin
05-28-2003 09:20:55
 Re: Re: Knockin in reply to BOB, 05-27-2003 19:35:58
There was an oil leak where the oil pump housing was cracked. I have not split her yet. I was tring to avoid that. All the teeth on the pump gear where in great condition. If she is choked the slightest bit the knockin really increases then. There is no known oil leak to be found. She hasn't lost any great amount of oil.(just what would normally be used) I've used the "screwdriver trick" to pin point the sound. It seems to be about 5-6" below the spark plugs. Would it help to drop the oil pan, or is that a waste of time? Thanks in advance,again. Justin
