Order Ford 8N Parts Online
8N distributor bushing replacement
LEWIS J
01-05-2001 11:39:20
does anyone know the best way to change the bushings on a front mount 8n distributor
Red Raider
01-05-2001 14:40:30
 Re: 8N distributor bushing replacement in reply to LEWIS J, 01-05-2001 11:39:20
Made a huge difference in performance once the bushings were replaced on my 9N. I would guess the slop created a big gap on the opposite side of distributor where the rubbing block had pushed for who knows how long. It almost wore through the brass bushing. I don't know which plug that post was connected, but I'm sure the spark was haywire. Smooth as silk when replaced.
Claus
01-05-2001 12:12:59
Drive out the old ones and drive in the new ones. The way to do it is with a bushing driver set. They cost about $10.00 or so at one of the junk tool places...
Happy Motoring
Claus
STUMP PULLER
01-05-2001 17:07:54
 Re: Re: 8N distributor bushing replacement in reply to Claus, 01-05-2001 12:12:59
WHEN I DID MINE THERE WAS HARDLY ANYTHING LEFT TO DRIVE OUT. THE ALUMINUM HOUSING REALLY SIEZES BAD. I ENDED UP SLICING THROUGH IT WITH A HACKSAW BLADE AND SLOWLY CHIPPING IT OUT. THE NEW ONE SHOULD DRIVE IN EASY. I DRILLED A HOLE IN MINE FOR THE OILER. GOOD LUCK
