Order Ford 8N Parts Online
8N front mount distributor internals
bj/8N/mt
01-05-2001 08:15:56
I have my 8N front mount distributor on the bench and recall some posts about a fiber washer causing trouble. Can't find anything like that. Does anybody have a picture? thought as long as I had it on the bench I might as well do whatever it needs
Nextly, there is a wire bale on top of the advance plate that doesn't show in the I T photos. Does this do anything?
Happy New Year to All, etc.
Ed Gooding (VA)
01-06-2001 03:56:27
 Re: 8N front mount distributor internals in reply to bj/8N/mt, 01-05-2001 08:15:56
See if this will help you out:
third party image
Happy New Year..... ..... ..... .Ed
'52 8N475798
bj/8N/mt
01-06-2001 08:00:08
 Re: Re: 8N front mount distributor internals in reply to Ed Gooding (VA), 01-06-2001 03:56:27
now I am really confused--does this washer go under the condensor lead on the brass coil screw?
is this a special [FNH] part or would any electrically insulating washer work?
thanks for the help to date
Fast Ed Ohio
01-05-2001 11:10:45
bj/8n/mt , try going to nseries.com You will see under maintenance, front mount distributor, click on this, you will see information and pictures of front mount dist.
Claus
01-05-2001 08:25:16
There is a fiber insulator that insulates the coil connection from ground. It is part of that top hat bracked that holds the front bushing in place. When the points and capacitor are changed and the brass screw is overtightened, it will cause the fiber insulator to short out. The threaded insert where the brass screw goes into, has a sqare brass boss that when it is turned it may break the insulator. The bale on top of the advance plate keeps the point plate in place.
Happy Motoring
Claus
bj/8n/mt
01-05-2001 09:18:01
 Re: Re: 8N front mount distributor internals in reply to Claus, 01-05-2001 08:25:16
thank you, sir
