Order Ford 8N Parts Online
8N Fan Belt
Kelvin
05-14-2003 19:30:26
What's the easiest way of replacing the fan belt on an 8N with a Wagner loader on it. The hydro pump drives off of the crank pulley. Taking the hydro pump loose doesn't give enough room to replace the belt. Is there an easy way of doing it short of loosening the front end???
souNdguy
05-15-2003 05:43:44
 Re: 8N Fan Belt in reply to Kelvin, 05-14-2003 19:30:26
You could get one of those adjustable belts.. some kind of fiberglass interlocking product.. lets you make vbelts of just about any size, .5 inch increment at a time... not a temp belt either.. sopposed to work as good as a solid one.
I saw them displayed at my local bearing shop.. they were red in color and rated for industrial use.
Soundguy
Hobo,NC
05-15-2003 04:15:19
Theirs a splined pump shaft that should slip out of the front pulley and also they used a shaft that is treaded in to a hub that conects to the front pulley with four fingers (pins) on that type you will need to un screw it from the hub (it is left hand tread) You may hace to remove the hub frome the front pulley then to replace the belt, It should slip off the front of the pulley. On the splined type you may have to remove the four bolts that hold the hub to the pulley.
Kelvin
05-17-2003 21:59:08
 Re: Re: 8N Fan Belt in reply to Hobo,NC, 05-15-2003 04:15:19
Thanks guys. The shaft from the pump has four pins that fit into the pulley on the crankshaft. So tomorrow I'll head out and see if I can unscrew the hub from the shaft. Thanks again.
Salmoneye
05-15-2003 04:52:20
The front loader pulley that cam with mine had internal splines and was held onto the front of the crankshaft with four socket head cap screws...Think they were 1/4 inch allen head...
