Left my key on
Buckeye Fan
05-08-2003 19:46:11
How much damage will be caused by leaving the key on for 7 days? I know it is a dumb thing to do but it happens. Thanks, Buckeye
Lee
05-09-2003 11:07:08
 Re: Left my key on in reply to Buckeye Fan, 05-08-2003 19:46:11
I'm guessing that since it started the coil is probably OK. I'd drop in a set of points and condenser(check the cap and rotor as long as you're pulling the dist.) and go from there.
duey
05-08-2003 21:42:29
If the points happened to be open, perhaps nothing bad. You could be lucky.....
bg
05-08-2003 19:48:07
It can run the battery down and burn the points and/or condensor and may fry the coil. Will it not start now?
Buckeye Fan
05-09-2003 03:55:34
 Re: Re: Left my key on in reply to bg, 05-08-2003 19:48:07
I got it started but it doesn't seem to have much power and it misses pretty bad, I'm going to pull the dist. and check the points. It is a front mount. IF the coil is bad will it be visible? Thanks for the help.
MikeC
05-09-2003 06:11:14
 Re: Re: Re: Left my key on in reply to Buckeye Fan, 05-09-2003 03:55:34
If the coil is bad there is no visual way to find out-the damage is internal. If you know how to take voltage readings you might be able to tell. Personally I would buy a new one and put it on. If worse comes to worse you will have a spare for when the coil really does go bad.
