6 Volt Cigarette Lighter
NAA
01-04-2001 04:47:50
Anyone know where to locate a 6V cigar lighter for an 8N/NAA/Numbered Series? I have heard that the lighter is the same has a 40 - 50's Ford Truck?
Dave Todd
01-04-2001 19:46:28
 Re: 6 Volt Cigarette Lighter in reply to NAA, 01-04-2001 04:47:50
Thanks guys!!!
Dave
9N'er
01-04-2001 13:33:36
on page 55 of the owners manual for the 600 and 800 series it shows the cigarette lighter as an option item. It is located above and to the right of the main bolt that holds the lower dash unit on to the steering support area on the same side as the key switch (or left side) of the lower dash unit. of the three items on the lower dash they form somewhat of a triangle. Beginning with the the key switch and going counter-clockwise tand dwon is the bolt for the lower dash and then up and to the right is the ligher...and then back to the key switch. If I was adept at computer stuff, and had a scanner I could post a picture for ya. hope this helps. 9n'er
NAA
01-04-2001 15:17:39
 Re: Re: 6 Volt Cigarette Lighter in reply to 9N'er, 01-04-2001 13:33:36
third party image
Attached is a pic out of the 1953 Jubilee tractor accessories catalog - it shows the lighter to be the same has the 8N and mounted on the LH side near the ignition. I have also seen the location that 9N'er described for the 600 and up numbered series
Dave Todd
01-04-2001 13:15:37
I have been toying with putting one on my 8N, but where did it mount?? My 8N is a 51. Anyone have any info on where it is supposed to go??
Thanks!!
Dave
