Order Ford 8N Parts Online
8N Oil pan
CHRIS B.
05-05-2003 19:23:45
Need to remove my oil pan and head cover to replace pistons and conecting rods. Two screws at the front of the tractor seem impossible to get to. Any suggestions or do I take off the entire front end including Hyd. loader.
yes . . . Dell(WA)
05-05-2003 20:09:10
 Re: 8N Oil pan in reply to CHRIS B., 05-05-2003 19:23:45
Chris..... the front axle is bolted to the front of the engine oilpan (6-bolts). You MUST remove front axle to remove oil pan. You MUST remove front end loader to remove front axle. And you MUST remove hood to remove cylinderhead. And you MUST remove cylinderhead to remove pistons out the top of the engine block. And you MUST remove the engine oilpan to remove the pistonrod bolts so you can remove the pistons out the top of the block.
Suggest you seriously consider the merits of having your own personal I&T FO-4 repair manual, $29 cheap..... ...respectfully, Dell
CHRIS B
05-06-2003 11:35:02
 Re: Re: 8N Oil pan in reply to yes . . . Dell(WA), 05-05-2003 20:09:10
Dell, thanks for the help. Manual is already om the way should have it any day now
