Order Ford 8N Parts Online
8N and low RPM
James Kluttz
05-05-2003 16:30:40
My 8N is suffering from low RPM. Even at full trottle it runs like it's at low to mid trottle. I've checked to make sure sure it's getting fuel and that doesn't seem to be the problem. I don't have any trouble starting it either. Air flow seems normal as well. Any suggestions of where else to look ?
MikeC
05-05-2003 16:34:12
 Re: 8N and low RPM in reply to James Kluttz, 05-05-2003 16:30:40
Check your connections to the govenor and make sure that when you increase the throttle the govenor is responding. You can even disconnect the govenor and operate the carburetor linkage manually to see if the problem is the govenor.
