Lift Piston Removal?
New Charlie
05-04-2003 19:05:08
I have the lift cylinder out and the piston is at the bottom.
Any trick way to get it out?
Otherwise, I will make a plate with an o-ring and fitting to pump oil in to push it out.
Thank you
Charlie
MATT (BC)
05-05-2003 10:48:36
 Re: Lift Piston Removal? in reply to New Charlie, 05-04-2003 19:05:08
If you have the cylinder off and don't have compressed air to force the piston out. You can force the piston out as I did by placing a board on the bloor and banging the open end of the cylinder against the board. The piston will eventually move to the open end for easy removal unless the piston is rusted into the cylinder. The best way is still using compressed air.
Willy-N
05-05-2003 06:30:56
After you remove the cylinder from the housing you will see a hole that the Hydraulic Fluid goes in. Wrap a towel around the cylinder loosely and use the blow gun on a air hose put the tip in the hole and just blow a little air in it. The towel will keep the piston from flying accross the shop when you do it if you used to much air. Mark H.
raytasch----------CAUTION-------
05-05-2003 05:26:29
Compressed air is a good way to remove it. Use extreme caution when removing the piston with compressed air. It can come out with great force.
ray
Buckeye Fan
05-04-2003 19:10:26
Charlie, I used a little air pressure and popped mine right out. If you have access to an air compressor, thats the easiest way to do it. HTH, Buckeye
Fast Ed Ohio
05-04-2003 21:53:36
 Re: Re: Lift Piston Removal? in reply to Buckeye Fan, 05-04-2003 19:10:26
Yea, I used my compressor and it came right out but I cant remember exactly how I did it. I do remember I used the blow gun .
Fast Ed Ohio
05-04-2003 21:53:21
