2n will not idle ??
Charles Parker
04-28-2003 18:43:03
Everything seemed to work great(show tractor)but had to park it inside for about 4mo. Getting ready for another club show and it will not idle.All throtle linkage is very tight but the idle screw and shaft will not come to rest position.Govenor linkage also has no play.Thanks for any HELP given to a tinkerr!
Dell (WA)
04-28-2003 19:07:20
 Re: 2n will not idle ?? in reply to Charles Parker, 04-28-2003 18:43:03
Charles..... ....by complaining "2n will not idle" doesn't really give a person much to guess on. Try an be a little more descriptive.
If the tractor idle hunts, (fast and slow) thats usually clogged jets from evaporated gasoline over the winter storage. In which case, time for carburator cleaning.
If the tractor is just fast idleing, disconnect the spring loaded carb to governnor rod and see if engine idles down. If it idles down then your problem is the governor and time for a governor rebuild..... ..... .respectfully, Dell
Drmeatman (Thanks Dell)
04-28-2003 19:17:41
 Re: Re: 2n will not idle ?? in reply to Dell (WA), 04-28-2003 19:07:20
Thanks Dell! The later part of your help answer seems to fit and I'll check it first, but it is puzzeling that when I parked it,it would idle. O well strang things do happen.
