Order Ford 8N Parts Online
8N running poorly when hot
Bob
04-28-2003 04:59:18
My 8N runs fine for 15 or 20 minutes, then starts making a sputtering sound that sounds kind of like when you blow up a balloon and then let the air rush back out. At first the sound is intermittent, but soon it's constant. When it's doing this, there's no power at all, and any load kills the engine. This just started within the past week. Neither swapping the coil nor adjusting the carb helps. Any suggestions?
bg
04-28-2003 05:33:41
 Re: 8N running poorly when hot in reply to Bob, 04-28-2003 04:59:18
If all(tank, bowl, & carb elbow) fuel filters are clean and there is an ample flow of gas to the carb, and the float bowl is clean(no water or rust particles) and the carb is not varnished-up, the other option may be bad condensor, bad keyswitch or bad coil out of the box. Sounds like a classic coil or keyswitch problem, given the assurance of adequate fuel supply.
