1018 cold rolled steel
Joe, IN
04-26-2003 15:58:17
I have an addition I want to make to my 8N. I need a 2 1/2 thick x 6" x6" piece of 1018 or 1020 steel. Or, I could use two 1 1/4" x 6" x 6" thick pieces and weld them together to make one. I can't find a source. How much per pound should 1018 cost? One or the other should weigh about 26#. Any steel salesmen out there who could answer? Thanks.
BS@ElmaNY
04-27-2003 13:42:28
 Re: 1018 cold rolled steel in reply to Joe, IN, 04-26-2003 15:58:17
I used to go to an old welding shop years ago that had an old guy who'd do anything for you, or sell anything to you. Just a thought.
Cold rolled steel (CRS) is preferred over hot rolled steel (HRS) as it tends to be a bit more flat and be more within tolerances, especially for thickness.
The absolute strength of HRS is slightly higher than CRS. For your application that shouldn't be a concern.
Steel weighs 0.283 pounds per cubic inch, if memory serves.
Bri
Wayne Mo
04-26-2003 20:45:20
Steel costs about 30 cents a lb but you will be paying for the cutting to size and for a small piece like you want it will depend on what they have to start from.
Fessman
04-26-2003 16:14:19
I thought that McMaster Carr sold small pcs of steel. You could do a search on line for them, and search thier catalog.
Fessman
Jet9N
04-26-2003 16:05:05
Does it definately need to be cold rolled? Around
here you can usually find various thicknesses of
boiler plate in salvage yards. I recently had a piece cut to my requirements from a 1 1/2 thick
plate. Price was right.
HTH
Jet
