94 NISSAN AUTOMATIC TRANSMISSION FIXED!
ZANE
04-23-2003 19:42:00
Today I finally got my 94 Nissan Maxima up and running again after about a week of hunting for a used transmission that I could afford to put in my car. Never did get a good used one but did find one that had a hunk broken out of the upper rear corner where the shifter shaft enters the transmission. I had to pay the salvage yard $636.00 for a broken transmission with 105000 miles on it. I had taken my transmission down and found why Nissan transmissions are hard to find used. The planetary gears had been ground up in mine and come to find out this is a common ailment for the 94 Nissan Maxima transmission. Probably should have been a recall but they will last a little over 100000 miles so that puts them in the clear. (Planned obsolescency)
I took the planetary out of the broken transmission and put them in my transmission and then reinstalled it in the car and believe or don't it works perfectly so far. Mine had 127000 on it so I may have another 20000 or so miles to go before it shucks the planetary gears out again.
Anybody want to buy a nice clean good running shifting Nissan Maxima for $4,500.00????? It carries a 10 10 warrenty. Ten minutes or ten miles.
I'm not a very good salesman am I????
Hal/WA
04-24-2003 14:21:20
 Re: 94 NISSAN AUTOMATIC TRANSMISSION FIXED! in reply to ZANE, 04-23-2003 19:42:00
Amazing that the salvage yard would have the guts to charge $636 for a broken transmission! Supply and demand, I guess--they were able to get that much from you....
The Maxima is a neat, very powerful car that I admire a lot. My neighbor has one and it flies.
I will warn him about the transmission problems.
I think his is about a 97 or so. In your research, did you find that Nissan kept the same transmission in later years? Maybe they fixed the deficiency.
Congratulations on getting it to work. I have only been into automatic transmissions a couple of times out of desperation. Pretty complicated. I'm impressed.
Lee
04-24-2003 07:10:47
LMAO at salesman Zane. Glad to hear that you got it fixed. If you put an ad in the paper to sell it you might skip the history and warranty info. though. Thanks for the chuckle, Lee
dave#1
04-24-2003 04:06:14
That's not a bad warrenty, not as good as my 4-31 warrenty though..... "When your "4" wheels hit "Route 31" the warrenty is over!!!.....Route 31 is at the end of my driveway!!!
LOL
later"belch"dave
Don C
04-24-2003 02:23:32
Zane,
Do those trannys shift hard or something to make those plantary gears go like that. Or is there just too much power in the engine and a weak plantary link?
Glad you got it going again, but boy that's expensive.
Don
ZANE
04-24-2003 04:55:12
 Re: Re: 94 NISSAN AUTOMATIC TRANSMISSION FIXED! in reply to Don C, 04-24-2003 02:23:32
The car has a transmission switch on the console that says "comfort-normal-power"
I have always used it in the normal mode. I have tried it in the other two modes too. The comfort mode is smooth and sort of slips into gear and the power mode will put a crick in your neck when it shifts under full throttle.
I think the engine is too powerful for the Micky Mouse gears in the planetary. The shafts that the three planetary gear run on are about the size of a pencil and the material of the gear housing is soft so the shafts wallow out on the ends in the housing till one of the gears starts to take all the load then it goes. Not good!
Vern_MI
04-24-2003 05:18:33
 Re: Re: Re: 94 NISSAN AUTOMATIC TRANSMISSION FIXED! in reply to ZANE, 04-24-2003 04:55:12
The Planet gears and bearings in the Planetary (Simpson) gearset are the most difficult to lube. They rely on oil which is spun or slung off of the sun gear for their lubrication. In cold weather when the oil is quite viscous the gears get very little oil until the system heats up. Good case for synthetic here. Best bet is to keep the oil and filter (suction strainer) clean. IMHO the Saturn system with the bypass filter on the transmission is the best. Good luck with the rebuild.
ZANE
04-24-2003 17:52:17
 Re: Re: Re: Re: 94 NISSAN AUTOMATIC TRANSMISSION FIXED! in reply to Vern_MI, 04-24-2003 05:18:33
Another thing I forgot to mention is that the suction inlet screen/filter is not accessable from the outside of the transmission. The transmission must be broken into to replace the filter. DUH!
DallasGa
04-23-2003 19:49:27
Zane, Your no salesmen,but your one heck of a tractor guy.Stick with what you're good at!
