Order Ford 8N Parts Online
8N PTO JUMPS OUT OF GEAR
HANK
04-23-2003 16:16:16
RECIENTLY PURCHASED 8N AND INSTALLED A
FINISH MOWER.
IT OCASIONALLY JUMPS OUT OF PTO ON POSITION
AND MOWER SHUTS DOWN.
PLEASE GIVE ME A HINT OF POSSIBLE FIX
ZANE
04-23-2003 19:27:42
 Re: 8N PTO JUMPS OUT OF GEAR in reply to HANK, 04-23-2003 16:16:16
Examine the PTO shaft for in and out movement. If it will move in and out that is your problem. The bearing is moving in the housing or the bearing is moving on the shaft and either will cause it to jump out of gear.
Drain the oil from the differential in a five gallon container.
Remove the four bolts that hold the PTO housing to the back of the tractor and pull the PTO out and see what is the cause of the movement in and out.
Arne - Idaho
04-24-2003 08:37:55
 Re: Re: 8N PTO JUMPS OUT OF GEAR in reply to ZANE, 04-23-2003 19:27:42
If you have a cliper, depth micrometer, dial indicator with mag base, etc. You can check this without disassembly. Just pull it all the way out as hard as you can, take a measurement, and push it in, take another and do the math. Mine has about .030 play. It also comes out soetimes, but mostly with implements that don't have a well balanced PTO shaft. Is the shaft on your mower phased properly? (the yolks on the shaft should be 90 deg apart from each other)
Arne
Dell (WA)
04-23-2003 16:34:44
Hank..... ...there is a "ball-detent" in the tranny PTO shifter housing that sometimes gets loose (and lost). Depending upon your irritability tollarance, most just use a rubber bungee to hold PTO shifter lever in position..... ...Dell
