Order Ford 8N Parts Online
8N Marvel Carburator
Michael P. Desl
04-16-2003 16:46:37
One more for you - the tractor has a Marvel Carburator on it. There are two fuel adjustment screws on the side facing out. I found this link:
Link
Which says each should be turned out about onew turn - is that correct? The large screw on mine was out about four turns.
Dell (WA)
04-16-2003 18:11:47
 Re: 8N Marvel Carburator in reply to Michael P. Deslippe, 04-16-2003 16:46:37
Michael..... ...each and every carburator adjusts differently because each engine is different. 1 turn or 1-1/2 turns gets you kinda in the "ballpark".
Adjust the idle mixture (small side needle) for MAX IDLE rpm's NOT smoothest idle. Set idle speed to slow 400-450 rpms with throttle setscrew on backside of carb. (its a back and forth proceedure)
BIG front mainjet sets MAX POWER at MAX rpms UNDERLOAD. I sett'em at 2 turns and leav'em. Check sparkie color after using for a while, should be tanish/greyish, NOT SOOTIE BLACK. Soft sootie is sign of TOO RICH, lean'er 1/8 turn. White sparkie insulator is sign of TOO LEAN, tweak'er 1/8 turn for richer mixture.
Carburators are BLACK MAGIC, and I know all the incantations (grin)..... ....Dell
Michael P. Deslippe
04-17-2003 13:02:44
 Re: Re: 8N Marvel Carburator in reply to Dell (WA), 04-16-2003 18:11:47
That's great - thanks!
Until I get my manual, I'm working in the dark.
I've been working on cars since 1963, so these things aren't foreign to me - but the tractor ius definately old technology.
Do these things have problems eating unleaded gas?
no . . . Dell (WA)
04-17-2003 13:34:09
 Re: Re: Re: 8N Marvel Carburator in reply to Michael P. Deslippe, 04-17-2003 13:02:44
Michael..... ...N-Engines came from the factory with hardened exhaust valve seats. And the low compression flathead engine was designed for 75 octaine gasoline..... .BUT..... modern no-lead gasoline needs a hotter sparkie to prevent fouling. Autolite AL-437 is popular, equiv to Champion H-12, (OEM was H-10)..... ..Dell
Larry, Mo
04-17-2003 07:10:33
Excuse my dumb question, but, if I need to lean the mixture, do I turn the big screw in or out?
Thanks for your patience.
Dell (WA)
04-17-2003 09:08:49
 Re: Re: Re: 8N Marvel Carburator in reply to Larry, Mo, 04-17-2003 07:10:33
Larry..... ..generally accepted convention, in for lean, out for enrichment. Do it in 1/8 turn increments and observe the results. Go operate the tractor doing what ever for 15-30 minutes. Turn off the engine and pull a sparkie, look at the color of the center insulator. Sooty black, too rich, clean white, too lean. Looking for light gray or light tan or light yellow..... ...Dell
Why do you think......bg
04-16-2003 18:38:32
...they call 'em Marvels?
