Order Ford 8N Parts Online
8N Blowing oil out the crankcase vent
Mark
04-13-2003 11:44:22
I let her sit outside all winter this year. (What was I thinking!) It had a old 50/50 mix for coolant. Started it up today and it was leaking coolant from the gooseneck gasket. I added fresh water with a hose. (It took a lot, seemed about empty). Once running it started blowing oil out the crankcase vent cap. It did stop blowing it and the oil level looks OK but it smells like gas! I can't detect any coolant in the oil with my good eye. I pulled the hood, radiator and water pump. Will replace the water pump gasket.(The cause of the goose neck leak). What else should I be looking for? It's a front mount distributor model. Year unkown. (Can't read the serial number).
Mark
04-14-2003 15:48:36
 Re: 8N Blowing oil out the crankcase vent in reply to Mark, 04-13-2003 11:44:22
Here's the follow up. The coolant leak was just a gasket. The gas in the oil pan was because the float was all gummed up from sitting all winter. I rebuilt the carb, made a new gasket and she sounds fine now. (Oh, I did change the oil and filter twice just to get all the gas out).
raytasch
04-13-2003 17:51:59
Any holes on the left side of the block or on the cylinder head? Most usual place for cracks is front of the drain plug on the left side of the engine. Change the oil and filter, get the coolant leak that you know of stopped, start her up and keep your fingers crossed that the coolant stays at the correct level. If the oil smells like gas it has gas in it and gas is not a good lubricant. The gas got in the oil pan through a leaking float valve in the carb. Turn your fuel off at the tank. ray
