Order Ford 8N Parts Online
8N overheated, won't start now
Dennis
04-12-2003 20:38:45
I'd been mowing several days this week, running radiator cleaner through it (some holes looked plugged and it was running hot last year). Today after a couple hours, it sputtered & died. After cooling down it started, ran for a few seconds, backfired and will not even sputter since then. I took the carb off & apart, cleaned it out & put it back together. Still won't start. Last summer I replaced almost all the electrical components and it ran fine until today.
Dave OH
04-13-2003 23:24:21
 Re: 8N overheated, won't start now in reply to Dennis, 04-12-2003 20:38:45
Check for spark. I'll go for the bad coil. But jump the ignition switch first. But I would remove the thermostat and back flush that radiator and block.
There was a picture in the Archives of what an old radiator looks like, and it wasn't good. Block can get plugged also and you will be suprised what comes out while flushing it with the hoses off. If it is a front mount coil remember to stretch that spring before installing it.
Dave OH
Mountainman
04-12-2003 22:45:40
Sounds like coil failure if you have a frount mount model. If it starts when it cools off (like over night) then the coil would be #1 suspect.
Condenser and key switch are two other possible suspects.
Make sure you have good gas flow and that no crud remains in the tiny orifices in the bottom of the carb under the main jet.
hth
Mountainman...CA
Fast Ed Ohio
04-12-2003 22:22:03
I had an old Plymouth do the same thing, turns out the rotor cap broke when it backfired, easy fix.
souNdguy
04-12-2003 21:09:47
Go through each system one piece at a time. First, check for spark... If you have spark, check for fuel.. look for a good flow from the bottom of the carb with the plug removed. Is your aircleaner blocked?
If you have spark, fuel and air, try starting it with a whif of starting fluid. If it doesn't start on that, try a compression check and see what you have.
Soundguy
