Jubilee electrical
NAA-HVC-IOWA
12-31-2000 22:49:25
Thanks to all for help in getting my Jubilee started. Replaced battery cables, 2 wires to dash and wire to coil. Tractor now starts fine.
No I have distributor problems. I think cap is "leaking" (jumping) current back to coil... any suggestions? Also have possible bad primary terminal on side of distributor. Thanks again . . . HAPPY NEW YEAR to all you helpful N'ers!
Dell (WA)
12-31-2000 23:50:58
 Re: Jubilee electrical in reply to NAA-HVC-IOWA, 12-31-2000 22:49:25
New caps arn't that expensive and they do "wearout"..... Dell
Jeff
01-01-2001 05:17:17
 Re: Re: Jubilee electrical in reply to Dell (WA), 12-31-2000 23:50:58
I agree with Dell. Caps do acquire "hairline" cracks within the cap causing arcing between terminals and elsewhere. Rotors also acquire cracks from its electrode tip to the distributor shaft in an effort of the high voltage to "ground out"
NAA-HVC-IOWA
01-01-2001 13:48:59
 Re: Re: Re: Jubilee electrical in reply to Jeff, 01-01-2001 05:17:17
I believe you guys are exactly right. I took the the distributer cap off as well as the cap over the condensor. The cap over the condenser is cracked and even flaking off around the center hole under the dust seal on the condenser side of the cap. Tractor runs but very poorly. Thanks!!
