Buckeye, I just took another look at your nice hoe. Your outriggers are fixed - that is not hydraulicly lowered like mine. Your hoe depends upon the tractor lift to lower the outriggers down to brace the hoe and then raise the hoe so you can move it. With that design you cannot use a rigid frame like mine. But you could easily make a similar frame for your hoe. The top link that you have now would not be used. Rather you would have to have a solid bar with a hole at the end to hook to the tractor rocker. Then close to that annother hole that you could put a long pin through to fasten/unfasten the side angle braces. The side angle braces would need to be adjustable, so I would use two adjustable top links like I see you are now using as the top link on your hoe, one on each side. They would then fasten at the other end on pins (like the lift pins) located near the standard lift pins. NO, I just took anoother look - standard adjustable top link will be too short. That means that you would have to fabricate and weld to the current hoe frame, a structure that would let you mount the pins necessary to hold the side braces. Or you could "lengthen" a pair of adjustable top links. In operation it would work like this; With the side braces off you lift the hoe and move to the job site. You lower the hoe and then fasten the side braces, adjusting them so they are pushing the bottom of the hoe down. Run the hoe, and then reverse the process to move the hoe. AHH, now I know why the designer did not have a fixed frame like the Woods. And he took a short cut to keep the hoe cost down by eliminating the cylinders necessary to lower the outriggers. I think he could have used one cylinder in the center if he had made the outriggers rotate to make them lower and raise. Then he could have used the fixed frame like the Woods. Looking at your hoe (again) I see that the outriggers look lke they are made of square tubing fastened to the bottom of the hoe. If you "cut off" the tubing you could remount those square tubes in a round tube so it would rotate, actually two so there would be a space in the middle. In the center you could than fasten an "arm" that a cylinder would operate. I can't see how much room there is between the hoe and the tractor, but that is where I'd try to put the outrigger cylinder. You would have to add some structure for the cylinder to "work" against when it lowers the outriggers. But the same structure could be made as part of a fixed braceing frame like the Woods frame. I think you could get by with a short - and thus less costly - cylinder. You might think about designing what I have described and see if you could "sell" it to the people you got your plans from. With a nice hoe like you have, you don't want accidents. Regards, Larry
