Order Ford 8N Parts Online
2 inch rear wheel nut...??? 8n
dale b [ ontari
04-07-2003 06:03:54
the centre nut on the rear wheel was so loose i could turn it off by hand.
this side also leaks oil.
the other side has two of these 2 inch nuts on it.
how tight should they be? should i have the tractor jacked up to tighten them? will a tigh
it nut help with the leaking oil?
if i can turn it off by hand, i guess the wire thingy needs replaced???
this is my first 8n. i have always had 9s 2s.
i thank all in advance...
dale b
ont. canada
J52J
04-07-2003 19:24:22
 Re: 2 inch rear wheel nut...??? 8n in reply to dale b [ ontario canada ], 04-07-2003 06:03:54
Here is more about the torque.. from Page one. I didn't know if you seen it or not..
dale b...........thanks
04-08-2003 03:10:33
 Re: Re: 2 inch rear wheel nut...??? 8n in reply to J52J, 04-07-2003 19:24:22
thanks for all the help guys, i appreciate it...
dale b
Jason
04-07-2003 13:01:54
If you take that nut off and your hub comes off easy the hub is worn. The hub has a taper to it so when it is pressed on it has some fire power behind it when you knock it off. My neighbors foot found that out! Just wanted you to now if you have to go any farther other then the nut tightening. saftey first!
JWichman
04-07-2003 06:55:35
From what I've read, the nut is supposed to be torqued to 450 ft-lbs, in that case you'd better have the tire on the ground when tightening. Also the loose nut causes the hub to wear which in turn causes the leaking. Again this is not from any personal experience (I haven't attempted fixing mine yet), but just what I've read on this board.
J52J
04-07-2003 06:53:57
The 2" nut should be tightened to 450 pounds.. I put my biggest brake over bar on it that I had and a 4 foot pipe on it and stood on it..
You might jack up that side and tighten the nut as much as possible, to get the hub drawn back as much as you can. But I would put the weight back on it to try to tighten it down.
If you get the hub tight, there is a good chance you will stop the leak depending on how long the thing was loose.
I'm sure someone here has a better answer than this but this is my 2� worth.
Happy Tractor-N
J52J/Jess
dale b
04-07-2003 07:41:40
 Re: Re: 2 inch rear wheel nut...??? 8n in reply to J52J, 04-07-2003 06:53:57
thanks jess,
i had no idea about the 450 lbs. wow.
it would be nice if it fixes the leak.
dale b
