Left brake pedel bushing?
ScottGa
03-26-2003 21:22:27
My left brake pedal is really sloppy. FO-4 doesn't show a bushing on the pedal side,only on the clutch side.Is the the bushing on the brake side part of the shaft? Does it have to be replaced as a unit? Any help will be welcome.
Scott-NC
03-27-2003 09:23:11
 Re: left brake pedel bushing? in reply to ScottGa, 03-26-2003 21:22:27
9N/2N or 8N? My 2N had sloppy pedals. Rebushing fixed the clutch pedal, the brakes (both sides) bolt to the cross shaft and use a woodruff key. Both of my cross shafts were badly worn where they pivot in the rear axle trumpets as well as where the clutch pedal pivoted. The bushings in the trumpets were also worn. Ended up building the shafts up with weld and turning them back to one inch diameter. Bought new bushings for the housing trumpets and used a brake wheel cylinder hone to size them to the cross shaft. Right or wrong, I also drilled and tapped the clutch pedal for a grease fitting and ground a small circular groove inside the pedals bushing to allow the grease to encircle the shaft.
