2-N with a King Kutter finish mower
Jim
03-26-2003 14:34:09
I'm downsizing from a larger tractor and bought a 2N. I am wondering if it will safely run my 5' finish mower which has a TAG ON IT SAYING "35hp GEAR BOX".
DOES THIS MEAN THE ENGINE HAS TO PUT OUT 35 hp TO RUN THE MOWER? If so my 2N is short on power. If this is the case---
What rating mower would some of you, who know more about this than I do, recommend? I guess I could hook it up and try but I don't want to tear up my 2N. One fellow I talked to said there is no way that little tractor can run that particular mower. and it will tear up my transmission HELP...
Al (Mo)
03-26-2003 19:24:55
 Re: 2-N with a King Kutter finish mower in reply to Jim, 03-26-2003 14:34:09
My 9N runs a 6' King Kutter finish mower in 2nd no problem.
George Willer
03-26-2003 18:57:15
Jim,
Don't listen to that "one fellow". The mower has no effect on the transmission. I have two 9Ns, each running a 6' mower. They usually do it in second gear.
That 35 HP rating is the MAXIMUM the mower can safely hold back. A higher horsepower tractor can be used on it with caution, but it will have enough power to burn belts, etc. in heavy mowing.
George Willer
Ron (8n509270)
03-26-2003 16:07:13
I run a 5' KK behind my 8n
Bruce (VA)
03-26-2003 15:56:23
Jim, I've got a 6' Caroni finishing mower I pull with an 8N; works fine.
Dell (WA)
03-26-2003 15:09:09
Jim..... .....that tagged gearbox is rated 35hp MAX. Most 23 hp N-Tractors handle 5' finishing mowers just fine. And if'n ya runn into some heavy grass that kinda boggs ya down, mow about 1/2 mower width..... ...Dell
