Order Ford 8N Parts Online
8N clutch
Mapledale
12-30-2000 06:19:42
When I first start my 8N when it's cold, I have to keep the clutch in with the transmission out of gear or else she'll stall out. When I slowly let up on the clutch, the tractor wants to move, while not in gear. Is this a bad clutch or is the linkage going bad? Once the tractor warms up, it doesn't do it.
Thanks
Claus
12-30-2000 06:28:14
 Re: 8N clutch in reply to Mapledale, 12-30-2000 06:19:42
When it is cold, the fluid is like mollasses and when the clutch is out, the counter shaft turns in the mollasses. This puts a load on the engine. This happens especially, when one uses the 90 weight oil. You may want to switch to 134D in the winter it this bothers you.. Not to worry....
Happy Motoring
Claus
Claus
12-30-2000 06:30:41
 Re: Re: 8N clutch in reply to Claus, 12-30-2000 06:28:14
One more thing....Almost forgot... Ensure that the PTO is not engaged, as the pump will try to pump that fluid..
Happy Motoring
Claus
