2n/9/n qeustion need help
Doug hargrave
03-20-2003 05:53:57
I recently changed the pison in the hydrolic system to help the 3-point hold my plow, now for some reason the control handle springs back to the up postion all the time by itself, could someone please tell me what I need to do to stop this becuase it did not do that before!! thanks Doug
rick craig
03-20-2003 16:46:28
 Re: 2n/9/n qeustion need help in reply to Doug hargrave, 03-20-2003 05:53:57
them ole hydraulics are funny things. get enough back pressure on them and they will reverse. kind of like when your pullin up the arm on a back hoe. just as you get it real close instead of continuing to pull back on the lever you flick her real quick the opposite way and she comes on in and locks down. dont know if this helps or not. just my thoughts. be safe. rick craig
ZANE
03-20-2003 06:07:39
May need to tighten the friction clutch nut on the end of the quadrant shaft so the clutch can hold it a little tighter.
Or you could look at the link below for a better solution.
Zane
Zane, ... HI
03-20-2003 09:23:32
 Re: Re: 2n/9/n qeustion need help in reply to ZANE, 03-20-2003 06:07:39
I always poke a hole in the bottom of the aerosol paint cans, CAREFULLY.
Well, I just fond an "INDUSTRIAL BLUE MARBLE: in a JD green spray can. USED TO BE BALL BEAR'ns.
COLBOLT BLUE at that! Chinese checker collection.
Here's to you. Thanks for list'n.
