3 point hitch mount
joe
03-17-2003 10:22:18
My 8n 3 pt hitch lower left mount is leaking and when i try to titen it up it spins so without touching the casing is their another way to seal it. PS thanks for the great feed back , joe
Fast Ed Ohio
03-17-2003 23:33:09
 Re: 3 point hitch mount in reply to joe, 03-17-2003 10:22:18
I see removel of axel trumpets in your near future. Good luck .Dont put it off ,the problem just gets worse if you dont.
Ken N Tx
03-17-2003 13:04:42
See the above post for a picture...
Dell (WA)
03-17-2003 11:59:42
Joe..... ....Unfortunately the lower 3-point pin is held in the diffy case by a castelated nut and cotterkey. Torque to 150 ft/lbs. And the ONLY WAY you will be able to tighen it is to remove the rear axle trumpet. Get out your I&T FO-4 manual $29 cheap. Axle trumpet removal is mostly gruntwork but doo-able by shadetree mechanic..... ..Dell
