Let me preface this. I converted a front mount 8N last week and with your alls help it runs fine. Now I am converting a side mount 8N, got it wired and it won't shut off.Before I thoroughly explain my wiring, I'll tll you that the 2 post terminal block was broken and I am using a ballast resistor in place of it. I refer to that as "1st resistor" from here on out. Here goes: 1) Wire from the distributor post to the + post on 6 volt coil 2) Wire from - post coil to the left side of the 2nd ballast resistor 3) From the bat post on the alt a wire goes to the + post on the ammeter, P2 short wire to bat post on alt, P1 goes to one wire on the side marker lite, the other wire from the side marker light goes to left post of the first resistor. 4) Solenoid small post wire to starter switch, from the bat post a wire goes to the - post on ammeter 5) On the ignition, the yellow wire goes to the right post of the 1st ballast resistor, the black wire goes to the left post of the first resistor. 6) There is a wire going from the right post of the 1st ballast resistor to the right post of the 2nd resistor also. 7) there is also a short wire from the - post on ammeter that goes to the left post of the 1st resistor. I wired it exactly like the drawing with the exception of using a side marker lite (which the drawing did not call for and the original terminal block was missing a post so I used a ballast resistor. Any Ideas. It runs fine except it won't turn off????? ??? Thanks, Dave Brown
