Aux. fuel tank
Bee in Mo
03-13-2003 17:53:46
Hey, found something new today when I ran out of gas down in the bottom pasture. Was looking at the sediment bowl and noticed the printing on the valve wheel saying open 2 turns for the main tank and all the way for the aux. tank. Opened it and got me back to the barn. My question is ,should I leave it open to use up the old gas or does the gas mix between the main tank and the aux. tank? Thanks in advance. Bee
Rusty
03-13-2003 19:08:17
 Re: Aux. fuel tank in reply to Bee in Mo, 03-13-2003 17:53:46
There is a tube that sticks up about an inch inside the tank. You ran her till the gas went down past that tube. Leaving the reserve gas in the bottom of the tank. When you opened the valve all the way you gave her your last couple inches of gas in the bottom of the tank.
Jeff Hoo
03-13-2003 19:05:03
As Ron said, the sediment bowl valve sucks through a 2 inch or so input tube in the "reserve" mode, and then from the bottom of the tank when you back the knob all the way out. So the gas is all the same. Pretty cool that Henry saved you a walk back to the barn so many years after his passing....maybe you should drink a cold one for him, eh?
Ooops. Jeff Hoo
03-13-2003 19:11:22
 Re: Re: Aux. fuel tank in reply to Jeff Hoo, 03-13-2003 19:05:03
Typed it bass-ackwards. I meant the tall tube is in "main" mode, and back all the way out is reserve. MORE BEVERAGE!
Ron (8n509270)
03-13-2003 18:17:36
It is all one tank. The gas will mix. The main and aux tank are controlled by different link tubes attached to the sedimment bowl. If that makes sense.
