Order Ford 9N Parts Online
9n cut out
John
03-12-2003 19:32:03
Had a dead battery, and I jump started the old girl. But when I shut it off the amp gauge showed a 20 amp discharge. So I started checking the wiring and found a few bare spots, but still had a discharge. So I went to the selinoid and started checking wires there and sure enough I found one drawing juice with the key off. Came to find out the wire was to the cut out and generator. So I ran to Napa and bought a new cut out $77.95 plus a new selinoid $19.95. Installed them and cured the problem. Sure wish we had a tractor supply handy besides mail order. Since Cetral Tractor closed the parts for these old tractors just keeps going up. John
Jim WI
03-13-2003 11:20:55
 Re: 9n cut out in reply to John, 03-12-2003 19:32:03
The last time I bought one (about 5 years ago) it was only $13.95 at the NAPA store. I think you need to have them check that price!
ED-IL
03-13-2003 07:59:56
I agree with everyone else, $77.00 is too steep for a cutout regulator. I have had a very good experience with an aftermarket voltage regulator device that replaces the cutout.
Third Party Image
Even this little gem, however, is only $68.00.
R.M. In AL.
03-12-2003 20:14:41
I bought a cutout for my very early 8n and it was omly $15.95 you must have bought somthing else.They make a new type that looks like a cutout but is actually a vr in a round can. Maybe you got one of those. Wow 77 bucks.I sure would hate to blow that thing up. R.M. In AL.
Jim Cox
03-12-2003 20:06:12
has anybody ever tried using a 'square can' VREG, just for the cut-out? May not look original, but doggone $70.00+??? Maybe I could have done the same thing with a Big Diode. BTW that's why alternators don't need cut-outs. the Rectifier diodes don't allow the Battery current to discharge thru the stator windings when the alt output voltage is below battery voltage.
Hmmm Diode....anybody wanna be a guinea pig for this experiment? Your opinion Dell?
Jim Cox
Starter Rebuilder Guy / PT Electronics Teacher
Dell (WA)
03-13-2003 09:40:07
 Re: Re: 9n cut out in reply to Jim Cox, 03-12-2003 20:06:12
Jim..... ...it would have to be a "power diode" capable of 30+ amps and probably 200+ piv (generator brush hash) and would probably have to be mounted on a insulated heatsink. And since all diodes have a 0.6 v turn-on knee, thats 10% of your 6 volt generator output. Bottom line, I don't think I'd use a diode as a "cut-out" relay replacement.
But I'd sure 'nuff get one of them thar "fun products" 6 volt transisorized voltage regulator "cut-out" replacements..... .....Dell
klf
03-13-2003 07:46:33
Yeah, when I studied phyisics, I remember that current will only pass through a diode in one direction.
klf
03-12-2003 19:42:12
Where are you located? NAPA really gets top dollar for that cut out.
John IA.
03-13-2003 17:27:56
 Re: Re: 9n cut out in reply to klf, 03-12-2003 19:42:12
Perry, Ia. Yes, I will agree. The last time I bought one it was under $20. And it was a round tin can. This one is a little rectangle job and evidentialy made of gold on the inside. Cause I didn't get no vasoline and I had them check the price twice. But it works. John
