Order Ford 8N Parts Online
Landscape Rake and 8N
Chuck in Kansas
03-11-2003 08:53:44
I would also like to get a landscape rake for my 8N to rake my pastures, I have lot of pecan trees that drop a lot of small branches. Do the landscape rakes work, or is it an item that looks good, but doesn't work well in the real world.
Thanks
KWP
03-11-2003 14:20:53
 Re: Landscape Rake and 8N in reply to Chuck in Kansas, 03-11-2003 08:53:44
Didn't seem to work to well for me. With no down pressure the rake seemed to raise up over the limbs, however it might work okay if you try to add some weight and set the top link at an aggressive angle. They do work great for the finishing touch on a gravel drive or a ball diamond, or smoothing dirt to lay sod, that kind of thing.
LarryNAA
03-11-2003 09:04:59
I have a rake for my NAA (Jubele, and I use it to rake horse pasture. It does a good job breaking up the 'Horse Apples' spreading them around. It will rake up branches into piles pretty well. Of course, it's very good at raking gravel, hence the nick-name 'stone rake'. Does pretty good raking out dirt, too. In the pasture, I've used it to rough up the soil in prep for over-seeding. You can remove every other tooth, if you need it to be more aggressive at scratching the ground.
