3 point hitch drops??
Duane
03-11-2003 03:44:46
This is such a great site!! Anyway most of the time when I am using the backblade the blade will drop if I don't hold the handle up. Can anyone tell me what I have to do to fix it? Thanks in advance.
Duane
Ron from IL
03-11-2003 06:57:42
 Re: 3 point hitch drops?? in reply to Duane, 03-11-2003 03:44:46
Duane,
You can make a superior friction disc from heavy gasket material. The O.D. is 3", the I.D. is 5/8". I used Garlock 1/8" material and a gasket cutter. They last a lot longer than the cork ones.
Good luck!
Ron
Dave Smith
03-11-2003 03:51:17
If you have to hold the lever in the up position, you probably need a new friction disc Part #518 behind the lever.
Dave <*)))><
Arne - Idaho
03-11-2003 06:33:06
 Re: Re: 3 point hitch drops?? in reply to Dave Smith, 03-11-2003 03:51:17
Be careful when taking the nut off to replace the friction disc. Mine broke off at the base of the threads.
Arne
