Order Ford 9N Parts Online
9N with Side Dist.
bigdawg
03-06-2003 18:38:53
I have a 9n with 12 volt and side distributor. It is starting hard in cold weather and I am in the process of replacing plugs, wires, etc.
I assume I just need to order points, rotor, and cap for a side distibutor?
I've check the compression and it is 88-90 on all four but only starts in idle and needs to be nursed along for a while before it's on its own.
Doug Wisconsin
BigDawg
03-08-2003 06:12:48
 Re: 9N with Side Dist. in reply to bigdawg, 03-06-2003 18:38:53
It was a whooping 30 degrees yesterday and I finally got a chance to remove the spark plugs and put in new. WOW - how wsa this thing even running. The plugs were very bad.
I put in new plgs and new wires and ran out of daylight for the rest.
I went to start and it started right up, better than ever.
Thanks to this board, I didn't mess with the carb.
Best regards everyone,
Doug
Wisconsin
RoN of ohio
03-07-2003 14:17:06
Seems funny to me. I thought all these old internal combustion engines had to nursed along on start up when they are cold. And as long as all cylinders are basically the same compression,and up near 90 lbs. I'd say they it is about where it should be. Other than being a little finecky on start up, are there any problems with with the side mount?
MikeC
03-06-2003 18:57:40
Since 9N's did not come with a side mount distributor, I assume that you either have a swapped engine from an 8N or your tractor is an 8N. So you will need to order parts for a side mount 8N engine. Since yours is a 12V conversion I won't even attempt to tell you how to troubleshoot the electrical possibilities.
88-90 is getting low. Were those numbers wet or dry? Compression that low could mean a couple things-if it is consistant along all cylinders I would suspect rings. That could account for hard starting. I would rule out weak spark or other electrical/fuel issues first though.
Bigdawg
03-06-2003 19:17:19
 Re: Re: 9N with Side Dist. in reply to MikeC, 03-06-2003 18:57:40
I was told that the engine was rebuild and the side distributor was added during the rebuild.
I wonder how I time this beast?
I have a 3 speed trans. with Sherman overdrive. Break pedals are on opposite sides like 9N.
Engine seems fine once it is warm.
Best regards,
Doug
Wisconsin
Rusty
03-07-2003 21:23:53
 Re: Re: Re: 9N with Side Dist. in reply to Bigdawg, 03-06-2003 19:17:19
You may just have to let her warm up a little before you runnoft. Got one that will not go cold. Once she warms up everything is great. Very dependable. I really need to install a thermostat. You can look in the arcives and find a post on timing the tractors without timming marks. I think Zane posted a trick or two that worked for me.
rbell
03-07-2003 05:50:05
Could be a 9N engine with an adapter, or a combine engine with a mag converted to distributor or a ?????
Any markings on the distributor?
BigDawg
03-07-2003 06:08:57
 Re: Re: Re: Re: 9N with Side Dist. in reply to rbell, 03-07-2003 05:50:05
It was sold as a 1943 9N Ford tractor SN 107824.
The distributor is in 2 pieces. The cap and a plastic cover over the points.
I'm just going to clean the old one up and see how it works. Then find a local dealer and match it up. Once I know what I have I can order it the next time.
Should make timing it interesting. Don't think there are any timing marks on the flywheel.
Oh Well - I wanted something to tinker with and I guess I got it.
Thanks,
Doug
klf
03-07-2003 21:00:32
 Re: Re: Re: Re: Re: 9N with Side Dist. in reply to BigDawg, 03-07-2003 06:08:57
They didn't make the 9N in 43. The 2N came out in 1942. The 9N was 1939-1942. Must be someone put a late model 8N engine in a 2N.
