Back Blade Snow Wing
MAX
12-26-2000 15:34:11
I have a 6 foot back blade that I use to push snow off the driveway. What frustrates me is when it is turned at an angle I can't push the snow off as far as I want to. Is there a "wing" I can attach to the one side of the blade so that it is more like the snow plow trucks?
Scott
12-27-2000 20:27:44
 Re: Back Blade Snow Wing in reply to MAX, 12-26-2000 15:34:11
Back in Michigans UP a buddy of mine fabricated wings for his 2N blade. He took a 55 gal drum, cut out panels to match the curve of the blade, and bolted it on with angle iron as a rear brace. It seemed to work well. Make sure to mount the bottom of the barrel panel 1-2 inches above the cutting edge of your blade. This way, the barrel doesn't actually do any cutting, but moves the snow out another 3 feet.
Cost? barrel-$5.00 Angle iron-$10.00 Welding and bolts? take your neighbor a half rack.
Scott
Ed Gooding (VA)
12-27-2000 07:37:54
Max, does your back blade offset? Some are mounted on rails so that they slide in either direction when you loosen the nuts, some like mine you have to remove the bolts, slide the blade down to the next set of holes and then reattach the bolts. This helps a lot, especially when you are going up one side of the driveway and back down the other. However, if you are not comfortable steering with your brakes, you should probably practice some, because with an offset blade full of wet snow, your steering wheel will be about useless.
fwiw..... ..Ed
'52 8N475798
Steve IA
12-27-2000 03:58:58
Don't have a picture, but here's what I do. I lag screwed 3 8-foot treated 4X4s together then lag bolted the whole mess to my 6 foot blade. The blade even had 2 holes on each end so it was simple. I picked up 4x4s that were bent and twisted at the lumber yard for a few bucks so it cost me very little. The extra foot on each side of the blade helps tremendously moving the snow outside the wheel tracks. My blade is heavy and the extra weight of the wood makes the front end more squirrely, so I'm looking for some front end weight now. HTH Steve 8N 169302
TC in Black Dia., WA
12-26-2000 19:03:31
Max, good question...I have the same back blade and although it rarely snows here in the Seattle side of the Great Northwest I occasionally get to push the white stuff (good excuse to head to the shop). I know of no commercial "wing" but if you find one shout. I may try it.
