Back/Scrapper Blade ?
Karl
02-20-2003 11:46:08
Hi All,
Given all of the snow in the Northeast, my 4-wheeler with a plow has done well, but I need some real push power. I want to use my 9n and a backblade. However, before I invest $$$$ any tips on getting one. I would be willing to buy used, if it works.
So far I have quotes on new:
Woods $425, BrushHog $299, Landspride $363
from various dealers.
Less money is good for me, but I don't want to buy something that'll breakdown or not work as well.
Any thoughts or knowledge of good places to get blades, please let me know.
Thanks,
Karl--
Ron (8n509270)
02-21-2003 12:08:42
 Re: Back/Scrapper Blade ? in reply to Karl, 02-20-2003 11:46:08
6' From Tractor Supply for $169.
Ron
BUY USED! Bob in NY
02-20-2003 19:33:17
Why buy a new implement for a 50 year old tractor. I bought a USED 6' for $125 many years ago. I mow the "lawn" with a 5'Woods mower, and don't want ruts,so I don't use calcium. Pulling snow without calcium or chains is good for about 40 feet, so I push. Usually a herringbone pattern works best for me. Handled the recent 18" of snow easily, but hard to push it up ontop of the existing frozen piles of snow. Kinda rough on your neck, continually looking backwards, but a "you poor thing" neck massage from the wife helps. Bob,in lower Hudson Valley, NY.
Pitch
02-20-2003 16:09:24
I have a 7' king kutter and I can turn it around when it is set right. I live in Upstate NY so I plow snow with mine all the time. The secret is is to do it early and often. I do six or eight inches in third gear and the snow rolls off quite nicely. When you get so it is pulling the tractor around just back into the pile and knock some down use the back side of the blade. It isn't neat and pretty but it gets the job done. By the way I have Hiway chains and unloaded tires, and a level drive.
SteveB(wi)
02-20-2003 15:55:16
'76 4X4 Chevy, Posi front & rear, 8' Meyers hydroturn. Wipers, heat and stereo included. 2000# of lannon stone in back and chains on rear for the rough stuff. I'd rather get my N time in a T shirt and shorts!
duey
02-20-2003 14:11:43
I've got a back blade....better for dirt than snow. If, and I say, IF, I was going to deal with snow, I'd come up with a FRONT blade, for sure. Nothing is as convenient as the 3 point hookup, but for snow, the front blade is what I'D do.... Snow is better dealt with form BEHIND the blade.. which is why you turn the back blade around and push backwards. Visibility and handling are WAY better going forward, you even get several speed choices... why, it's darn near NORMAL!!!! Disclaimer: Free advice is worth what you pay for it... duey
Brian-2N
02-20-2003 14:07:00
Karl,
Many of us use backblades. Mine is a Landpride. Contrary to what Dan says, the low height won't mean the snow falls over the blade. I just plowed 2 feet on snow this Tuesday and it worked fine. Here are some tips. Load your tires and get chains. Can't plow worth a damn without it. Pull, don't push, if you can. If you try to go in reverse you'll quickly find out that the blade digs in and you won't go far. Sometimes you reach a spot when you can no longer pull and must push. DO NOT turn the blade around. Believe it or not you can push a lot of snow this way and no it does not topple over the blade. Note that it will not scrape down to the surface, soooo...., make a few pushes with the concave edge out, then reverse the blade to scrape the last inch or so.
I use a 6 footer, but at times I will I had a 7 footer, but I realize I couldn't spin around if I did. That's your call.
If you get a good model you should be able to offset left or right. If you start to get pulled into the bank use the opposite side brake to keep yourself in a straight line.
Used models depending on condition and size range from 250-350.
Hope that helps.
Dan (myersville)
02-21-2003 07:09:31
 Re: Re: Back/Scrapper Blade ? in reply to Brian-2N, 02-20-2003 14:07:00
Heh Brian,
Whats your technique for avoiding snow spilling over your blade? Ihave to push/pull snow 75-100' or more straight ahead to a point where it can be pushed to the side. Have 4-5' stone walls on either side so angle plowing when depth exceeds 1/2' is not an option. Pulling the other direction is up hill so not an option even with chains and loaded tires (which I have). Have found no way to push that much snow with my back blade. If snow is fluffy, once pile gets over about 3' high, blade simply buries into base of pile and pile collapses behind blade. If snow is wet enough to compact and hold form it's too heavy to push. For snowfalls like we just got (2') I have to dig and dump to the side with the loader on my Kubota. Slow work with a 4' bucket.
Dan
Brian-2N
02-21-2003 09:05:06
 Re: Re: Re: Back/Scrapper Blade ? in reply to Dan (myersville), 02-21-2003 07:09:31
Depends on the type (wet or fluffy) of snow and how much.
Take small bites. If you can't angle to the side (which it sounds like you can't), keep the blade straight and pull only a small segment at a time. Your tactor will drive right through 2 feet of snow with the blade up until you reach your starting point. If you pull too much the tractor will stop. Pull a small amount and whatever accumulates behind the tractor will simply drag behind it. When you get to the end, lift the blade over it, put it in reverse, and push it into the bank (no need to reverse the blade). I try to keep my blade perpendicular to the ground. If this still isn't working, tilt the top of the blade toward the tractor to get the snow to tumble forward.
Just keep experimenting with different methods. That's how I discovered all the tricks I use.
Dan (Myersville)
02-21-2003 12:05:47
 Re: Re: Re: Re: Back/Scrapper Blade ? in reply to Brian-2N, 02-21-2003 09:05:06
Yes, I've had many years of practice and am quite familiar with all of those tricks. As long as you're on flat ground with plenty of open space on the sides you can nibble away at large snowfalls with a back blade.
Which brings us back to my original point which was that you cannot push or pull a clean path of any distance through snow that is close to or deeper than the height of the blade. The blade simply undercuts the upper portion which collapses behind the blade. You'll have better luck angling than pushing straight ahead but if the height disparity is 2:1 as it was in this last snowfall here neither works reasonably. You have to nibble. Possible solution - better snow blade with twice the height, preferably front mounted so you don't get a crick in your neck.
With regard to driving an N through 2' of snow - try that on a slope of say 15% and let me know how it works - up, down and sideways ;-)
Brian-2N
02-21-2003 12:40:53
 Re: Re: Re: Re: Re: Back/Scrapper Blade ? in reply to Dan (Myersville), 02-21-2003 12:05:47
Dan,
With the blade straight, pick a point close to where you're going to end up dumping it. Drop the blade into the snow and pull. When you get to the end lift the blade and push it into the bank as I said. I agree, once the side banks get too tall you can't angle the plow anymore. I'm sure a front blade is better, but as it requires counterweight, and the N doesn't have 4 wheel drive, among a host of other complications, most of us make do with a rear blade.
BTW-my 2N is parked at the bottom of my driveway. I started from a dead stop uphill through 2 feet of snow-no problem. Ditto when I when across the road to do my neighbor. Pretty steep angle too.
Dan (Myersville)
02-21-2003 13:48:02
 Re: Re: Re: Re: Re: Re: Back/Scrapper Blade ? in reply to Brian-2N, 02-21-2003 12:40:53
Obviously you need to choose the tool to fit the job at hand. Different circumstances often dictate different solutions. Hopefully Karl isn't totally wacked by this discussion ;-) All he wanted was advice on choosing a blade.
Dan
Paul
02-20-2003 14:05:38
I have a King Kutter 7' blade which I payed around $226 or so. So far its been great, but with the 7' blade I have run into the problem of not being able to turn it around while on the tractor.
Dan (Myersville)
02-20-2003 13:18:49
The only effective way to push (significant) snow with a a back-blade is backwards (i.e. blade turned to the rear and tractor driven in reverse).
Otherwise the snow collects under the lift arms, especially if at all wet. Front mounted blades are vastly superior unless you're an owl. Also, the moldboards on most back-blades are ill-suited to pushing snow - too short and the snow spills over the top too easily. Snow blades are generally much taller. All that aside, major items of interest when choosing a back-blade:
1) Good sturdy angle adjustment. Dinky (5/8") pins through a single plate will shear, bend, or worry the adjusting holes badly when you catch the blade on something that doesn't give (you will - repeatedly). I've modified my 6' LandsPride blade to use a 1" pin through both the top and bottom of the 4x2 box steel frame. The two points of support provided by the top and bottom holes spaced two inches apart keep the pin vertical and maintain the blade angle much better than the original single 5/8" hole in the top. I reinforced the original top hole with a 1/2" plate AFTER the original 5/8" hole became an oversize oval. 2) Good sturdy moldboard - see 1 above.
3) Reversible cutting edge - extends life
4) Adjustable offset blade is a plus (extra money though) Allows the blade to be extended left or right of center. Great for edge plowing pavement without getting the wheels off the pavement. Allows a shorter blade to extend further beyond the wheels on ONE side of the tractor when angled.
Indispensible for cutting ditches.
I would expect to be able to buy a good 6' blade with offset for under $350. If you have to choose between features and "beef" to stay on budget buy the beef. Three-point equipment gets a real beating and it's amazing what you can break and/or bend.
HTH,
Dan
Jerry, S.E. Mich.
02-22-2003 11:20:37
 Re: Re: Back/Scrapper Blade ? in reply to Dan (Myersville), 02-20-2003 13:18:49
Last month a good friend of mine bought a 7' blade at T.S.C and the second time he used it for snow removal he hit a frozen stone and busted the weld on the main center support. The blade twisted 20 degrees and was unusable. He figured that for under $200 he got what he paid for. They were very good about taking it back but it was the inconvience of it all. They have a lot of good products but that blade really needs reinforcing. Jerry S.E. Mich.
Danny in CO
02-20-2003 13:04:53
Karl,
I have a 6' Landpride back blade for my 8N. My only regret is that I didn't get a 7'. When angled, the path isn't as wide as the rear tires.
2 considerations with a 7' blade: you may not be able to rotate it completely around without hitting the rear tires and with the blade wider than the rear tires, you could get the blade hung in tight places. On mine, I have the rear tires set out wide for stability and I believe a 7' blade would clear the tires when I rotate it.
Danny
OH Boy
02-20-2003 12:00:27
I think I saw some 6' King Kutter blades at Tractor Supply Co for around $200. That was in central Ohio, don;t know if you have TSC there or not.
I believe they have 7' too for maybe 20 or 30 dollars more.
Get a blade thats wide enough to cover your rear tire tracks if possible. Also consider the blade will be angled at times so a 6' blade will not clear a 6' wide path. I have a 6' wide blade and now I wish I had a 7 or 8 footer.
