3 Brush Gen Output?? Dell??
Joel (SoCal 44'
02-17-2003 06:31:53
What should the output range of the 3 brush generator be?? Mine doesn't vary (another trip to the rebuild place) but puts out about 6.3v.
Dell... This 2N is newly rebuilt, 6v and shall remain, as it starts ever so easy.
Stick with the Mantra!
Thanks, Joel
Tony
02-17-2003 16:15:28
 Re: 3 Brush Gen Output?? Dell?? in reply to Joel (SoCal 44's), 02-17-2003 06:31:53
Are you taking off the access cover and moving the third brush? This is how you vary output with a 3 brush. Set output low when not running lights etc. or you'll cook all the water out of battery, set output high when running lights etc. to maintain charge. If you move third brush and output does not vary its time to take the generator apart and/or trip to the electrical shop (assuming the shunt regulator is working properly).
Jim Cox (SW Missouri)
02-17-2003 11:12:57
11A is the current, voltage anywhere from 7 to 7.5 with the throttle up halfway or more
Jim Cox
Starter Rebuilder Guy
Dell (WA)
02-17-2003 07:46:48
Joel..... ...3rd brush generator is rated 11 amps output..... ..Dell
