Order Ford 9N Parts Online
9N Radiator Cap Question.....
TooDawgs
02-16-2003 15:10:26
Can anyone tell me the lbs. pressure the radiator cap should be on my 9N. Again, any help will be much appreciated. And thankz to everyone for all the help with my previous questions. I really hate sounding like a complete dummy.
TooDawgs
RoN of ohio
02-17-2003 07:08:37
 Re: 9N Radiator Cap Question..... in reply to TooDawgs, 02-16-2003 15:10:26
Hey TwoDawgs. You never should think that you have to appologize for asking questions on this forum. I think that I speak for most of the people here when I say that I learn from your questions as much as my own. And as most of like challinging our brain pan ever once in a while, We enjoy getting questions when we know the answer. Sometimes, you will be referred to the 'archives' for answers. That is mostly because some of the past answers are more detailed and/or sometimes you can skin a rabbit several ways. Thanks for the questions. It keeps some of us older "N'ers" (and I am referring to myself, not 'Ole One Eye' contented for another day. Sincerely...Ron
Dell (WA)
02-16-2003 16:32:10
2-doggies..... ....what Jay sez..... .except.....
The orignial 9N radiator system was un-pressureized. Later, many early 9N's were upgraded to the 4 psi radiator system simply by swapping for late model radiator.
NOTE: the radiator pressuration is controlled by the radiator cap. In late 40's automobiles changed to 7 psi. Current radiator is 14 psi.
NOTE #2: the non-pressureized early 9N radiator cap/neck is NOT interchangeable with later 4 psi systems. The non-pressured 9N system has the cap locking lugs on INSIDE of radiator neck. Pressureized radiator necks have locking lugs on outside of neck..... ...Dell
Jay 2NSC
02-16-2003 15:55:32
Hi TooDawgs,their is no dumb question here I'm told,4lbs is the anwser.Hope this help's.:')Jay 2NSC
TooDawgs
02-16-2003 21:11:58
 Re: Re: 9N Radiator Cap Question..... in reply to Jay 2NSC, 02-16-2003 15:55:32
Thankx again you guys....mine must be a 4 pounder then I guess. The locking tabs are on the outside of the neck. The guy I bought it from said he just put in a new radiator & water pump & stuff so I'm pretty sure he put in a newer radiator. Also, I was told the point gap on these tractors was something like .018...and the plug gap is .025.....do you know if this is correct? I bought plugs, points, condensor & rotor and I'm going to attempt to install tomorrow. It's amazes me that someplace like O'Reilly's Auto Parts still have books that cover parts for these old beauties. Would it be just as easy to remove the hood for easier access to plugs & distributor?
thankx, TooDawgs
MikeC
02-17-2003 02:51:37
 Re: Re: Re: 9N Radiator Cap Question..... in reply to TooDawgs, 02-16-2003 21:11:58
I just did a front mount distributor yesterday. The point gap per the F-O4 manual and the instructions with the FNH kit and the feeler gauge that came with the kit were all .015. Spark plugs are .025.
You will have a couple of gaskets that you might want to change out too. One for the distributor cap, one for the coil and a paper gasket for the distributor to engine.
Dell (WA)
02-16-2003 21:32:56
2-doggies..... .....would you believe to replace your points in your frontmount distributor, you remove the distributor (2-bolts) and take it into a warm house and doitt on the kitchen table? The distributor is driven by off-set cam and it only fits 1-way upon installation. Yep, points 0.018 and plugs 0.025. Timing is 1/4" (0.250). Really need a picture to understand how to set the timing. Gettcha an I&T FO-4 manual, $29 cheap..... ...Dell
