Order Ford 8N Parts Online
8N overhaul
Doug
02-16-2003 07:38:13
I have an 8N that has been setting in the field for a few years. I decided to restore it and have started taking it apart. I have the pistons out and will try to figure out which piston sleeves I need. I guess I can mesure the old sleeves at the top were there is no wear. From reading other articles I suppose I should take the crankshaft out and have it turned. Does anyone have any advice on the pitfalls I should avoid and where I can get overhaul info. or manuals. I probably should replace the pistons while I am at it (or should I?) Also what order do you recommend that I take for the restoration process,will apprecitate any advice.
FO-4 Manual
02-16-2003 09:30:55
 Re: 8N overhaul in reply to Doug, 02-16-2003 07:38:13
You need to get an FO-4 manual - available from the sponsors of this site or your local tractor dealer (New Holland & others).
"I guess I can mesure the old sleeves at the top were there is no wear."
The difference is in the sleeve's thickness, the ID should be the same for both .090" sleeves as for the thin ones.
hth
Mountainman...CA
Doug in Texas
02-16-2003 20:42:00
 Re: Re: 8N overhaul in reply to FO-4 Manual, 02-16-2003 09:30:55
Evil Steve,Mountain Man and others, thanks for the info, this will help me get started. I will take the advice and replace all things that you would normaly replace with the engine torn apart.
I found out that I do have the cast iron sleeves.
I will go ahead and get the new pistons at this time. Thanks, Doug in Texas
manuals would help
02-16-2003 07:42:24
