Gee, I have a Woods BH750 backhoe that I use on my Ford 3000. It has a "Saf-T-Lock�" hitch that keeps the hoe from raising up and crushing the operator between the hoe and the tractor. I assume (HOPE) that the Caddigger has something similar. That means that you should not and can not use the lift - once the hoe is attached. You might need to use it to get it attached. I used to but it was SO hard to get it to adjust the small amounts needed, that I finally build a wood frame that the hoe sets on when off the tractor AND under which I can set three screw jacks so I can lift and manuver the hoe the small amounts need to get the pins to align so I can attach the hoe. So do as Dell says, put the touch control lever ALL the way down and the mode lever in positon control. A backhoe puts enormous loads on the top link rocker - which is a casting. I broke mine on my 3000 using the hoe. Then I knew why Woods said to replace the top link rocker with a steel weldment that they made just for the 3000. If I could I would attach the hoe to a fixed point and NOT use the top link rocker. Using the top link rocker is BAD - I messed up the internal hydraulic controls on my 3000 because of the loads transmitted into it from the top link rocker. If you notice, all the industrial type backhoes are bolted SOLIDLY to the tractor rear end. Then when you lower the outriggers the lifting load is carried by at lot of bolts and not just the ONE pin of the top link rocker. And all the digging loads are also carried by the bolts and not just that one pin. Since you have an 8N, you should have the "side ears" on the differential. Then the question is, do you have a solid or hollow pin holding the top link rocker to the differential case? If the pin is hollow you could use the long pin that sometimes can be found on the 8N's that extends through both ears. Otherwise you could fabricate (after all you build the Caddigger) something to attach to the ears that the hoe could be fastened to. If you come up with something clever and/or easy you should let the Cadplans people know so they could add it to their plans so other 8N users could use it also. I finally "cobbled together" a sort of "lock out" that keeps the top link rocker LOCKED in position so that it cannot work the inside hydraulic control system. Seems to work OK but when I finally get time to get into the hydraulic cover and fix it, I plan to design a BETTER way to keep the backhoe loads off the top link rocker. Hope I have given you some information to help you solve your problem. Regards, Larry
