BROKEN FRONT WHEEL HUB BOLTS- HOW BEST REMOVAL?
Cal8N-Modesto
02-15-2003 10:51:13
Have broken hub bolts on front of my '48 N. Do I use heat to remove? A strong hammer? Or do I have to take the hub to a press. Don't want to crack the hub. (And it is still on the axel spindle.)
-Cal
Dell (WA)
02-15-2003 12:00:19
 Re: BROKEN FRONT WHEEL HUB BOLTS- HOW BEST REMOVAL? in reply to Cal8N-Modesto, 02-15-2003 10:51:13
Cal..... ..wheel studs are press-fitt. If you know how and have the hollow backup anvil to take the shock of heavy hammer, you can usually poppem out. Otherwize, take the hub off and into a real machine shop with hydraulic press.
I don't think I'd burn'em out with torch because you can accidently burn the hole larger and then the stud won't stay in then hole..... ...Dell
