Order Ford 9N Parts Online
9N 12 Volt Conversion
Walter
02-15-2003 08:11:43
I have battled since 1992, with the 6Volt positive ground system on my 9N �Nellie�, to keep her running. I finally conceded defeat and recently purchased a 12 Volt conversion kit for the old girl. The instructions are pretty vague. They include a diagram with some notes. The conversion actually looks fairly easy, according to the drawing. I know from personal experience things are not always as easy as they seem. I do have a couple of questions. One note says �This is a 12 Volt system the battery must be changed to 12 Volt negative ground�. Do I need to do anything other than using the negative as the ground on the 12 Volt battery? Also does anyone who has done one of these conversions have lessons learned, that you are willing to share?
Thanks
Walter
duey
02-15-2003 10:08:54
 Re: 9N 12 Volt Conversion in reply to Walter, 02-15-2003 08:11:43
In reading your first question, it seems like you might be asking about actually DOING something to the battery..... what they mean is *remove the 6 volt battery and install a 12 volt battery, connect the negative post to ground*. Not sure if that was really the question, tho.....duey
Jay 2NSC
02-15-2003 09:42:00
Hi Walter,you can find a wealth of info in the archives above.HTH,Jay 2NSC
Dell (WA)
02-15-2003 08:48:43
Walter..... ..the 12 volt alternator absolutely requires 12 volt negative ground. There so many electrically challenged shadetree mechanics out there that don't know the difference so the 12 volt conversion kit mfg has to protect themselves.
Kinda like McDonalds and the hot coffee the lady spilled into her lap, claimed mickeyDee didn't warn her coffee was hot, sued McD and won millions..... ....Dell,..... . the 12 volt advocate for the right reason who sez: follow the kit mfg instructions and agrees that some kit instructions loose something in the translations to 'merican
The 12 volt conversion really is rather straight foward electrically, its when the electrically challenged try to outguess the kit mfr and confuse the 2 very distintly different N-Electrical systems that problems occure. I know of 7 different ways to convert to 12 volts and they all work. Just follow the mfr instructions.
If you still have questions, please post specifics about you question. Someone should be able help you..... .....Dell
