I have my regular 6v lights up front, and a worklight in back on the left fender on a seperate switch. I went to nappa ( car quest has them too ) and got a 6v 2 pole flasher for a volkswagon... Real easy to hook up.. 1 wire in one wire out... doesn't matter which direction you hook it up. Here's a trick to save wiring, like I did on mine. I like to use the light as a steady beam sometimes, and as a flasher if on the road. Run the power from the battery to the switch to turn the light on and off, and from there to the 2 ploe blinker assembly, from the blinker assembly to the light.. from the light to ground... you have a switched flasher light at this point. No, get another toggle switch ( or pudh buttone, or whatever ) and put that switch across the 2 poles of the blinker. What you are doing is making a shunt across the blinker , bypassing it when the switch is in the 'ono' position.. this makes it a steady lamp.... when the switch is in the 'off' position, current is again flowing through only the blinker causing it to flash. Works great! I concealed the wiring under the dash, so only I know to reach under and switch the 'mode' from blink to steady.. and the light switch itself is mounted on the light via some epoxy. A little sanding and painting and it looks pretty neat. Soundguy
