The front axle must be free to slide fore and aft as it rotates about the pivot pin. The radius rods will force it to do this as they rotate about the sockets at the footpeg end. When the front axle is angled to its limits, it also moves back 1/4 inch or so. The kingpin bushing, even new and tight, is also ineffective at stopping the front axle from attempting to pivot in a horizontal plane about a vertical axis (the way a kid's wagon steers). The 1/2 inch lever arm at the pivot doesn't compare well with the 30 inch long axle arm. Your radius rods take are supposed to take care of limiting this motion. The "excess motion" that a new kingpin bushing will fix is anything perpendicular to the bushing (up and down, and side-to-side.) It is this motion, when it gets bad enough and combined with the other, normal motions, that breaks distributor caps, hits radiators, or pushes the fan shroud into the fan. One way to diagnose the need for such repair, aside from taking it apart and measuring, is to jack up the tractor under the oilpan until it is just possible to pivot the axle and get both wheels off the ground, letting the axle hang from its own weight. Now lift up on one end of the front axle. Observe how much "lost motion" occurrs at the center pivot pin as the other tire contacts the ground and you continue to lift the axle. Also, try to slide the axle directly sideways. It has to be a pretty noticeable "clunk" in at least one direction before fixing it is going to do much for you.
