2n Draglink grease seals
MickPB
02-06-2003 19:07:18
I am trying to install new grease seals on the drag links. I was thrilled to get the parts but after trying for too long to get the first one installed I decided that I was doing something wrong. Can anyone please give me some advice? Thanks!
raytasch
02-07-2003 14:23:24
 Re: 2n Draglink grease seals in reply to MickPB, 02-06-2003 19:07:18
A 1-5/8" socket over the seal base and the seal against the drag link end between the jaws of a vise. About a 20 second job.
ray
ZANE
02-07-2003 05:40:42
Where did you get the new seals?
I need some on my tractor too.
Zane
Mickpb
02-07-2003 06:46:05
 Re: Re: 2n Draglink grease seals in reply to ZANE, 02-07-2003 05:40:42
Wow! I feel like a real member of the community now to have "Zane" ask me a question :-) Don B. at Just 8n's was my source. Prompt and curteous as always.
Also thanks to Patrick for the advice
Patrick (NJ)
02-07-2003 04:33:27
They are hard to get on without a hydraulic press.
Without one, I took a piece of pipe with an inner diameter just large enough to fit over the seal, missing the rubber part, but catching the lip of the lower metal ring. It is a tight fit.
I then mounted the arm in a vise and took a hammer and persuaded the seal on to the draglink by hammering the pipe. Once it gets going, the seal will go on fairly easily.
I'll bet one of the more experienced members has a better way and I'm looking forward to learning it.
Good luck
Patrick
