Intermittent leaking carburetor
ED
02-06-2003 13:52:43
my carb was leaking sometimes when parked,rebuilt it still leaked -about 1/2 of the time. had a tractor place rebuild it, still leaks, tractor runs fine. any suggestions on the intermittent problem? thanks
ih_bug
02-08-2003 23:17:06
 Re: intermittent leaking carburetor in reply to ED, 02-06-2003 13:52:43
add a little oil to the gas
don t. - 9n180179
02-07-2003 05:22:31
You could be getting garbage from the gas tank, passing thru to your clean carb, which in turn stops the float from closing the needle valve completly.
IF this is your case, 2 things you can do...
fix/clean/seal your tank or the not so recommend inline metal gas filter from NAPA.
As someone else suggested, turn the gas off at the tank. FWIW...good luck...don t. ...
simonmeridew
02-06-2003 18:26:39
I think your float setup inside the carb is getting hung up intermittantly. Take it out and make sure everything is straight and not bent; there isn't much clearance and it's easy for the float to catch on something, like an off center gasket, or the hinge mechanism might be hanging it up. You might look at something in the seat keeping the float valve from closing. It isn't rocket science.
simonmeridew
Ken N Tx
02-06-2003 14:20:22
The fuel system is gravity fed...shut off the fuel bowl when parked...Also your float valve could be sticking...
